Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro Door Striker Reinforcement Panel
Old 10-13-2008, 09:58 PM
Rag top bird's Avatar
Rag top bird Rag top bird is offline
Hot rods are still the king
If you are careful you can do this and not have to paint the outer quarter first you need the part in hand then make sure they are the same then if you look in the door jamb you can see the welds where the cage bolt is welded in take a 3/8 drill bit in a drill and drill the welds do not drill all the way through then take a hammer and a chisel and cut the rest apart from inside the quarter then fit the new one and weld through the old weld holes in the door jamb
