-   -   Camaro Front Clip spring options (http://www.hotrodders.com/forum/camaro-front-clip-spring-options-216383.html)
garretthes 03-09-2012 03:05 PM
A few years ago I grafted a 74 camaro front clip into my 59 Suburban. I had to use a couple of spring spacers to get the ride height where I wanted it. I really need to put the proper springs under it. However, I don't know which ones to buy. Looking for supplier that has this info. I know there is someone out there who has done this.
Houston54 03-12-2012 08:00 AM
Should be able to find what you need here:
http://www.pozziracing.com/camaro_spring_info.htm
enjenjo 03-12-2012 08:42 AM
There are a ton of stock springs that will fit. Any GM full size from a Caprice to a Caddy from 71 to 84 bolts in, as well as any A or G bodies from 64 to 77
