Camaro Front Clip spring options - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 02:05 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
A few years ago I grafted a 74 camaro front clip into my 59 Suburban. I had to use a couple of spring spacers to get the ride height where I wanted it. I really need to put the proper springs under it. However, I don't know which ones to buy. Looking for supplier that has this info. I know there is someone out there who has done this.
Old 03-12-2012, 07:00 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Should be able to find what you need here:
http://www.pozziracing.com/camaro_spring_info.htm
Old 03-12-2012, 07:42 AM
There are a ton of stock springs that will fit. Any GM full size from a Caprice to a Caddy from 71 to 84 bolts in, as well as any A or G bodies from 64 to 77
Front clip options for 59 Suburban garretthes Suspension - Brakes - Steering 6 02-21-2009 07:02 AM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
Camaro clip spring question joeinblueout4u Suspension - Brakes - Steering 9 07-27-2006 09:15 AM
Camaro front clip/ Yr???? Chevy535 Suspension - Brakes - Steering 3 07-21-2006 10:38 AM
Front clip options? bonuts Suspension - Brakes - Steering 19 04-14-2003 07:59 PM
