-   -   Camaro front sway bar measurements (http://www.hotrodders.com/forum/camaro-front-sway-bar-measurements-92328.html)
BK455 06-23-2006 05:10 PM
My new 1 1/8 " sway bar arrived and i am very suspicious that it is a bit too wide for my ride. I have a 68 and am doing up a new subframe with disc brake conversion. I installed the new sway bar and it is about impossible to put the end links in as they have to lean outboard at the top. The suspension is not loaded at this point, meaning the subframe is on horses with the spindles suspended in air. It appears that under heavy supsension compression, the steering arm could actuall interfere with the end knuckle of the swaybar. Does anyone have a sway bar around that they could measure the center on centers for me? The company i bought it from will do the same, as soon as they get another one in. That could take forever. I need to order one and get it installed prior to installling the front subframe to tub, makes things alot easier and would appreciate it.
Dennis
Deuce 06-25-2006 10:04 AM
Which brand after market sway bar did you buy ??
CDJr 06-25-2006 11:25 AM
My stock one measures 46 3/8" center to center, if that helps.
BK455 06-25-2006 11:40 AM
sway bar
I bought mine from Tamraz on ebay. Not sure what brand. They told me they have sold plenty without any call backs, but believe that the wrong one got shipped by accident perhaps. Thanx for the measurements. The 1 1/8" bar that they sent measured 46 7/8". I now know that it is indeed wrong. Would anyone perhpas know what this bar actually fits? Center to center is 46 7/8". Maybe perhaps early A body, such as 66 - 67 chevelle? Thanx for the replies.
Dennis
