Camaro front sway bar measurements - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2006, 06:10 PM
BK455's Avatar
My new 1 1/8 " sway bar arrived and i am very suspicious that it is a bit too wide for my ride. I have a 68 and am doing up a new subframe with disc brake conversion. I installed the new sway bar and it is about impossible to put the end links in as they have to lean outboard at the top. The suspension is not loaded at this point, meaning the subframe is on horses with the spindles suspended in air. It appears that under heavy supsension compression, the steering arm could actuall interfere with the end knuckle of the swaybar. Does anyone have a sway bar around that they could measure the center on centers for me? The company i bought it from will do the same, as soon as they get another one in. That could take forever. I need to order one and get it installed prior to installling the front subframe to tub, makes things alot easier and would appreciate it.
Dennis
Old 06-25-2006, 11:04 AM
Which brand after market sway bar did you buy ??
Old 06-25-2006, 12:25 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
My stock one measures 46 3/8" center to center, if that helps.
Old 06-25-2006, 12:40 PM
BK455's Avatar
sway bar
I bought mine from Tamraz on ebay. Not sure what brand. They told me they have sold plenty without any call backs, but believe that the wrong one got shipped by accident perhaps. Thanx for the measurements. The 1 1/8" bar that they sent measured 46 7/8". I now know that it is indeed wrong. Would anyone perhpas know what this bar actually fits? Center to center is 46 7/8". Maybe perhaps early A body, such as 66 - 67 chevelle? Thanx for the replies.
Dennis
sway bar fireemsman2 Suspension - Brakes - Steering 4 04-12-2006 04:33 PM
72 Nova Front Stabilizer Bar Bushings leejoy Suspension - Brakes - Steering 2 03-21-2006 09:16 AM
Now a Sway Bar question.... MM in NM Suspension - Brakes - Steering 5 03-13-2006 12:53 PM
Modify a sway bar street rod application?? sodas38 Suspension - Brakes - Steering 5 01-24-2005 08:03 PM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 03:25 PM
