camaro front tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2004, 06:27 PM
njbloodline666's Avatar
I Love VTec
camaro front tires
would 225/60 front tires be too wide to fit a 3rd gen camaro
Old 04-28-2004, 06:45 PM
I'm pretty sure you can go up to 245, depending on the wheel offset
Old 04-28-2004, 07:12 PM
I Love VTec
im not exactly sure of the offset, but they are the same rims i had on my 77 nova, the outer edge of the rim is about 1/2 inch from hitting the shock, should i use a spacer?
Old 04-30-2004, 09:27 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Biggest tires you can fit under a Third generation F-body without wheel well modifications are as follows:
15" Use 15x8 with 4 1/2 spacing 255/55
16" Use 16x8 with 4 1/2 spacing 255/55
17" Use 17x9 with 5 1/2 spacing 255/40 or less, 275 rear
18" Use 18x9 1/2 with 5 1/2 spacing front, 18x10 rear with 6" spacing 275/35 front, 295/35 rear.
1/2 inch is plenty with 60 or less side wall.
Old 05-01-2004, 06:37 PM
I Love VTec
thanks that helps alot
