camaro fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2011, 04:52 PM
87fubar's Avatar
just got back from having new pipes put in just wandering on this 97 camaro would i have to drop the tank to get to the pump or is there a access panel from inside the car
Old 05-19-2011, 05:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Either drop the tank or cut your own hole for it if you're able to do some simple fabrication w/sheet metal.
Old 05-19-2011, 06:46 PM
el pollo's Avatar
It's shady under this tree...
It'll be safer to drop the tank before cutting a hatch. But initially, the tank has to come down.
Old 05-19-2011, 07:36 PM
87fubar's Avatar
i was hoping there was easier way. i noticed when the car was on the lift getting new pipes about how much would have to come off to get to the tank
looked like a real pain.would it hurt the body of the car if i made an access point not use to these kinda cars
Old 05-20-2011, 12:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's no need to drop the tank before putting a door in the sheet metal, that's the whole point of doing it in the first place. Obviously just be careful to center the door over the pump. Be sure the door is sealed properly so there is no possibility of exhaust fumes to enter the cabin.
Below is what I used on a '94 after a pilot hole was made. A nibbler will also work:
MORE- http://www.camaroz28.com/forums/showthread.php?t=619463
Old 08-09-2011, 04:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by kleaver641
just be careful in dropping the tank
THE REASON IN CUTTING THE HOLE IN THE FIRST PLACE IS SO YOU DO NOT HAVE TO DROP THE TANK.
Spam is not allowed, either.
Electric Fuel Pump on 68 Camaro Curtis Thornton Engine 1 06-18-2010 10:27 AM
Electric Fuel Pump on 68 Camaro Curtis Thornton Engine 1 05-31-2010 05:52 PM
mechanical fuel pump on 86 camaro? garyl24 Engine 1 12-12-2009 01:23 PM
fuel pump died 86 camaro 86chevymomma Engine 10 09-13-2004 04:07 PM
3rd gen Camaro fuel pump -87Z28- Engine 6 06-11-2004 03:32 PM
