Camaro guru's what year spindle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2006, 12:12 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
I have welded a camaro frontclip in my 56 suburban, and want to order drop spindles.
Now i need to know wich year the clip/spindles are.
How can i find out?
They sell them for 70-74 , 75-78 and 79-81. I am confused.
This is how it looks right now.
Wander.
Old 09-25-2006, 12:40 PM
How do you know it's a Camaro clip?
Old 09-25-2006, 01:07 PM
I know how the camaro clip looks and it came from one, but dont know the year.
I had it laying around a long time before i had the time to start with the swap.
Wander.
Old 09-26-2006, 07:23 PM
There should be numbers cast or stamped into the spindles. Post them if you can find them. Some will be a part number, and some will be a date code.
Old 09-27-2006, 12:52 AM
I checked and found the numbers.
On my set;
371676 RH 7 GM
371675 LH 4 GM
And the size of the shaft is 1 1/4 for the inner bearing and 3/4 for the outer bearing.
On the car I build for a friend;
371676 RH 5 GM
371675 LH 4 GM
Was not able to pull the wheel and disc from ths car.
Wander.
72 camaro nose on a 78 camaro roy383ci Body - Exterior 3 02-25-2006 05:59 PM
76-77 Camaro? dannimo General Rodding Tech 10 12-11-2004 10:00 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
Future camaro dannimo Engine 1 12-06-2004 07:44 PM
Year One "metro" brand weatherstripping opinions 70-81 camaro bullheimer Interior 7 01-09-2003 07:03 PM
