camaro heater advice needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 04:39 PM
bullheimer's Avatar
NEVER use credit cards!
Post camaro heater advice needed
posted this in interiors but nobody responded all day. i have no heat thru any openings even tho i hear the blower working and the box is warm. cable from hot cold works, but the vent selector for defrost/heat/vent is vacuum operated and there is a hose hanging down from the heater box on to the floor that obviously connects to something behind the box. i will find it when i take it apart. i just need to know how to go about doing that!! it's a '72 model SS.
Old 02-05-2003, 10:16 AM
bullheimer's Avatar
Post
GUESS I'M TALKING TO MYSELF HERE, BUT IF ANYONE KNOWS OF A MANUAL THAT WILL HELP ME, LEMME KNOW. THANKS.
Old 02-05-2003, 07:54 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Bull, I just took mine out, its in a '77 T/A, but it can't be very different. Theres only two hoses behind the box, hotwaterinlet/outlet hoses. The two vents on either far side of the dash has one of those coragated flexible pipe jobbies going to them, the center upper dash vents have a plastic Y that goes from the left side of the box up(if your looking at it, its the left) That sucker is a real pain to take out, but if you do make sure you reseal around it because that is one of the things the create rusted floorboards in the passengers side. Didn't help very much, but its all I got and its better that whatcha got so far. Let me know how it turns out.
HK
Old 02-06-2003, 01:35 AM
Post
Alright I read it about 6 times more and here we go. Removing it will be very time consuming. You'll have to take out the dash to get the heater box apart. To take the box apart just remove all the vents and open your hood and take off all the bolts out around the perimeter, There are 8-10, can't remember off hand. Also disconect the hoses (of course). Don't worry about the 4 down the center they just keep the two peices together under the hood. After you remove the 8-10 perimeter bolts you should be able to pull the inside unit out. Like I said once you put it back in make sure you seal around it to make sure none of that water gets in there or you will have mushrooms growing in the carpet and eventually rusted floors.
HK
Old 02-06-2003, 11:02 AM
bullheimer's Avatar
Unhappy
god, HK, you really know how to make a grown man cry! <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> <img src="graemlins/pain.gif" border="0" alt="[pain]" /> anyway i fixed it. here is the click to my post: http://www.hotrodders.com/cgibin/ubb...001&u=00001073
late. <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
[ February 08, 2003: Message edited by: bullheimer ]</p>
Old 02-08-2003, 08:57 PM
bullheimer's Avatar
Cool
fixed it. click on above link. ok ok, i cannot tell a lie. my friend dave morris who works at chevy fixed it in less than 10 minutes.
Old 02-08-2003, 09:16 PM
Post
good to hear. Ride on.
HK
