camaro inquisitive - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 04:39 AM
camaro inquisitive
I recently came into a 1984 Chevrolet F body, 305, V-8, 5.0 at, 80k, one owner. all orig. 'CAMARO'. I am not real familiar with 4bb, and the tranny. What is the most important thing I should know and being it will be a classic in 2yrs. what should I check, change, or need to do?
Old 01-12-2012, 05:10 AM
Last journal entry: Still running strong
84 Camaro
I have a 78 Z28,all depends on what you want it to be.First thing to know is a 305 is'nt the best engine choose,get a 87 or later 350 at the least because they have more torque,pluse 87 or later have roller lifters & vortec heads or go with & LS engine.If it's & automatic trans you probably have a weaker 700r4, get a later 700r4 88 thru 92,their stronger,alot of the buggs were fixed. Being a junk yard searcher there's boat loads of them but maybe not for long.Here an engine tip Chevy 6 liter V8s will make 400 HP with just headers & nothing else. Of course it all depends on what you want.One more thing the rear diff is'nt all that strong,maybe a 12 bolt or a 8.5 diff.
Old 01-12-2012, 08:35 AM
Last journal entry: update
Did you consider that maybe the OP isn't asking about speed mods, but basic maintenance to make it last 2 years? For that car, all you need is www.thirdgen.org
93 Camaro converted to 96 Camaro LT1? tylerwerrin Engine 2 09-01-2010 10:11 PM
93 Camaro converted to 96 Camaro LT1? tylerwerrin Engine 1 09-01-2010 09:54 PM
93 Camaro converted to 96 Camaro LT1? tylerwerrin Engine 0 09-01-2010 07:56 PM
79 camaro hood hinges to 71 camaro swap Gladis Body - Exterior 1 01-10-2008 02:17 PM
Will a Tilt Column from 70-81 Camaro fit 69 Camaro? dpjmw Suspension - Brakes - Steering 2 07-04-2006 10:27 PM
