Camaro K-Members - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 10:18 AM
Camaro K-Members
Bought an '82 Camaro, cheap, has a factory 4-cyl TBI.
Swapping in a 350.
Any ideas what other vehicles I might be able to pull a compatible k-member out of?
Old 06-02-2010, 11:19 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As far as I can tell on those they all use the same engine cradle so all you need is the correct engine mounts..
Sam
Old 06-02-2010, 02:21 PM
ericnova72's Avatar
More for Less Racer
Sam is correct, all versions have the same cradle, you just need the correct mounts, mounted in the correct holes on the crossmember.
Old 06-03-2010, 09:55 AM
Awesome.
So, as far as the suspension goes, all I should have to change then is the springs?
Thanks guys!
Old 06-03-2010, 10:38 AM
ericnova72's Avatar
More for Less Racer
Changing the springs may or may not be necessary depending on what you are going to be doing with it. the 4 cyl springs work great for a drag car/street strip with alum heads, intake, headers and fiberglass hood, but if it is autocross or handling you are searching for you will need to make a change.
Old 06-03-2010, 11:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Camaro 3rd. gen front and rear spring p/n and specs. You'll see the front spring rates vary from the 300's to the mid 700's. I wouldn't be surprised if the struts were valved differently.
You can check your RPO code sticker to see if you have any suspension-related goodies like F41.
I wouldn't hesitate to build it w/the 4-cylinder suspension, just keep an eye on the ride height- especially if the springs are old.
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 12:01 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 01:30 PM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 10:29 PM
Just scored a Split bumper front clip for my Camaro Camarofiend73 Hotrodders' Lounge 2 12-15-2003 03:38 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 12:45 PM
