Camaro Rear End Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2008, 05:06 AM
What Rear End Gears Do Late 1970's Camaro's Have
Old 01-15-2008, 06:30 AM
dawg's Avatar
NAVY VETERAN
depends there was different ratios available
I had 3:50 ratio in my camaro back then
Old 01-15-2008, 08:38 PM
chevy3600's Avatar
http://community.webshots.com/
I bought an 81 Camaro rear to install in my 51 Chevy 3/4 ton truck. I don't know what ratio it was as the gears were well worn and I swapped them for a 3.73 set. If you want to know what ratio your's is, jack it up and spin the wheels. Count the turns on the drive shaft and the turns of the wheels. That will tell you the ratio you have.
Old 01-16-2008, 06:40 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
late 70ies camaro have the 8.5" 10 bolt diff
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Rear End Gears??? Phoenix7 Transmission - Rearend 8 11-10-2005 08:21 PM
spinning the rear end gears.. onecoomofo Transmission - Rearend 4 06-21-2004 06:19 PM
Rear end hum after new gears and carrier BH69Camaro Transmission - Rearend 2 09-21-2003 06:37 AM
Changing rear end gears... chevyelc81 Transmission - Rearend 1 07-23-2002 07:52 PM
