camaro rear end in an s10?
Hi all I am about to do a v-8 s10 conversion for thr first time. I have ordered the radiator, headers, mounts kit. and I already have a posi rear end out of a 1978 z28 I am just running thoughts through my head and was wondering if anyone has done this before? Im sure it will get better traction but I havent even measured it yet to see how much mod. needs to be done.
The spring perches, if not in the correct location can be removed and a new pair welded on in the correct location, I say new because of their relatively low cost.
I would definitely check for wheel mounting surface, to wheel mounting surface as it may be quite a bit wider than the S-10 axle, this can be overcome by using wheels with more backspacing. |
Thank you for the replies friends I will let you know how it works out
camaro rear in S-10
I have a camaro rear end (1976),and a 1988 S-10 rear end on the rack behind my garage and I can tell you that the camaro rear end is way wider than the S -10,didnt measure them but looks to be 3 or 4 inches wider. The S-10 rear you have is probably as strong as the camaro rear anyway.I ran a stock S-10 3,73 rear end with a built 350 for several years on the street and never broke anything.
camaro rear end width
I went out back this morning and did some measuring. The camaro(76) rear end measures 7 inches wider than the 88 S-10 rear end. there is no way you could use it under your truck. I measured from backing plate to backing plate.
| 8.8 Ford rear end in my 79 G body Malibu | 79 Malibu327 | Transmission - Rearend | 4 | 05-20-2007 02:26 PM |
| 67 camaro rear end question | shclayto | Transmission - Rearend | 6 | 10-11-2005 09:24 PM |
| Has anyone used an S10 rear end in a rod? | 48ChryslerRodder | Transmission - Rearend | 25 | 10-09-2005 08:17 PM |
| 96 camaro rear end fit in 84 regal | 225buick | Transmission - Rearend | 5 | 04-18-2003 04:10 PM |
| Camaro rear end in TRI 5 Chev Trucks | slider in wa | Transmission - Rearend | 2 | 09-25-2002 04:05 PM |
