Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - camaro rear view mirror on door -remote
Old 01-26-2003, 09:19 AM
bullheimer's Avatar
bullheimer bullheimer is offline
NEVER use credit cards!
Post
HK! thanks, i posted this at nastyZ28.com and the answer i got was there is a clip on the inside of the inside of the door that routes the cable to the front, then it goes under the window so i will look better to find it and stick it in there. i have the joystick part that the cables end in, i will need the part that holds that onto the inside door panel. i will definitely be getting that part if you have it. i will know in a few what's up after i find that clip and get the door panel on. i have to start moving today, but first i have to fix the front garage door where im going and add a back door to the hole that's there too. i have to be out on the 31 and that is a friday, hope my landlord lets me move next sat, but i'll be doin most of it at night. suck!
anyway, just looked. there IS a clip on the inside of the outside door skin. put the cables in it and now it works. also HK, thanks, but i just found that little metal bracket in a plastic baggie!!!!!!! im all set, but i think it will have to wait till dark, jesus it's rainin out there!!! maybe i'll have to forget workin outside. i also wanted to plant two 4x4 posts near enough to my garage to string a tarp across to protect the camaro. i have a feeling the windshield leaks, and i dont want water on my new carpet or worse, under the new felt.
[ January 26, 2003: Message edited by: bullheimer ]</p>
