Camaro Rearends - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2010, 07:07 PM
mre mre is offline
Camaro Rearends
What year or years did Camaro use coil springs on the rear axle,if they did at all ?
Old 10-31-2010, 07:31 PM
poncho62's Avatar
Wiki Edits: 5
Up until 1982 they all had rear leaf springs.......After that, dont know
Old 10-31-2010, 08:50 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
ya and im pretty sure after that they were coil springs
Old 10-31-2010, 10:27 PM
ericnova72's Avatar
More for Less Racer
'82-newer are coil springs, and use the weak 7.5/7.625" "baby" 10-bolt rear originally designed for the 4 cylinder Vega. Not an axle to use in any kind of performance build.
Old 10-31-2010, 10:35 PM
big gear head's Avatar
High Performance Rear Ends
Yea, leaf springs through '81 and then coil springs with the long torque arm from '82 to '02. I don't understand why GM couldn't use something stronger than the weak 7.5 rear end in these cars. Some of them made more power than most of the earlier cars, but the rear end couldn't handle it.
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 12:01 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 01:30 PM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 07:54 AM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 10:29 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 12:45 PM
