Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro rotors
Thread: Camaro rotors
Old 01-14-2013, 08:28 AM
joe_padavano joe_padavano is online now
I just did some checking. All of the GM rotors with the 5 x 5" bolt circle (full size police/taxi, half ton trucks, Astro vans) are 12" rotors. The wheel bearings are the same as on the Camaro, but the rotor is too large to clear the caliper mounting ears on the knuckle. Most of these are 1.25" thick, but some are the same 1" thick as your current rotors. Unfortunately, to make these work you'd need to turn the OD down to clear. All the 11" rotors (even from the B-body cars) have the 5 x 4.75" bolt circle.
