camaro specs
Hello
Where can I find spec dimensions for a 71 camaro subframe. Or does anyone know what points to measure to check subframe to see if its tolerances . Thanks Larry |
Info for contacting Chevy is HERE. A post I made on the subject w/info is HERE.
When you get them on the line, ask if that info is available to you- often they will (or they would, back in the day) get you the info while you wait. Ask about a resto-kit while you are there- I haven't checked on the price, the kits used to be free. If that doesn't pan out, that info should be available from a body shop. Good luck! |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| Camaro projects for sale... | Zartan | General Rodding Tech | 30 | 12-12-2008 11:01 AM |
| 78 camaro to t top 87 monte carlo help | isleofwight | Engine | 3 | 06-28-2004 09:29 PM |
| 68 Camaro 10 bolt & 2000 truck limited slip | 68CaliCamaro | Transmission - Rearend | 6 | 12-22-2003 04:57 PM |
| 94 Camaro lt1 Vs. 95 Camaro lt1 | NEEDHELP | Engine | 3 | 11-05-2002 11:45 AM |
