Camaro spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 09:33 AM
I was disassembling a 1977 Camaro subframe for rebuilding before I put it under my '57 Chevy truck. I found two cast aluminum spring pockets about 1" thick between the lower control arms and the springs. Are these factory parts, or were they possibly used to make up for weak springs? I had planned on reusing the springs, but now I my doubts. Any thoughts?
-Joe
Old 06-11-2006, 11:41 AM
Was the donor car a factory A/C car .. ?
Some GM cars have a 1 inch spacer from the factory to compensate for the added weight of A/C ..
Old 06-11-2006, 12:51 PM
Last journal entry: Buick
If you don't want those spacers I could really use them. I need to raise the front of my Camaro subframe 1 inch. PM me and we'll talk.
Rick
Old 06-11-2006, 01:46 PM
The donor was a factory AC car. The spacers look like horseshoes with a groove for the spring. If they are factory parts, I'm not going to worry about the springs. Free standing, they are the same height, for what that's worth.
Rick...if you want them, you've got them. I'll PM.
-Joe
Old 06-12-2006, 11:57 PM
I doubt if they're factory parts. More likely aftermarket stuff to compensate for sag, or maybe from an A/C kit. GM used different springs to compensate for extra weight.
1980 Camaro Question 80sCamaroChik Transmission - Rearend 3 10-24-2005 04:53 PM
67 camaro rear end question shclayto Transmission - Rearend 6 10-11-2005 09:24 PM
valve spring question.. HELP pi71 Engine 13 09-15-2005 11:15 PM
valve spring question BBCMudbogger Engine 15 08-26-2005 05:40 AM
Valve Spring question dion Engine 8 01-24-2003 12:53 PM
