camaro subframe tech ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2014, 09:26 AM
I installed a 76 camaro subframe on my 55 chevy and the track width is to wide for the nostalgia wheels I want to run. the wheels are old and I cant get them in a special offset. I heard that the 1970 camaro used the same frame but had a different track width (narrower). Question is can I buy different a arms or spindles or somehow narrow my track width without messing up the steering and suspension geometry, or at least not create any bumpsteer or major problems. I'm trying to narrow track width by 3". Also what is the best way to measure when the frame is done to see if it was done square. Thanks in advance
Old 01-29-2014, 10:28 AM
poncho62's Avatar
Wiki Edits: 5
My understanding was that the Nova subframes were a bit narrower than the Camaro ones. Not usre if it was the "A: arms or the frame itself.
If you have not done this yet, apparently the "G" body Chevelle, Cutlass etc frames are a better fit (a bit narrower)
Old 01-29-2014, 11:34 AM
life is a temporary assignment
The Nova is 1.5'' narrower then the camaro hub to hub,,
G" body Chevelle, Cutlass etc are 58'' hub to hub..
Old 01-29-2014, 11:46 AM
Banned
here is a quick fix , have your wheels narrowed . check the link out below.
Weldcraft wheels Narrow
Old 01-29-2014, 12:12 PM
techinspector1's Avatar
Wiki Edits: 326
Here's a listing of front track of various cars and trucks.....
Your '76 Camaro clip is 61.3" front track width.
'55 first series Chevy truck was 59.5"
'55 second series Chevy truck was 60.52"
'67-'69 Camaro was 58.7"
'78-'86 G body, as suggested by poncho62, was 58.5"
'74-'79 Mustang II was 55.6"
'83-'01 S-10 was 54.5"
As far as narrowing the track of the Camaro clip, I wouldn't do it, knowing what I do about suspension geometry. Either pull your horns in and use a wheel that will fit or get out the blue-tip wrench and change front clips. For your truck, the G body clip would be my choice, although the S-10 clip works out well too......
Advanced-Design Engineering S10 Frame Swap for AD Trucks
Last thoughts:
How about making some spacers for the front fenders, space them out by a couple of inches????
Old 01-29-2014, 12:22 PM
update
I didnt specify but its a 55 chevy car and the subframe is already installed with the sheet metal and core support trimmed and fitted, so I am trying to save it if possible
Old 01-29-2014, 12:40 PM
Wiki Edits: 326
Sorry, my mind automatically goes to trucks. The stock front track on your Chevy would be 58.5". I really don't see any option except to change your mind about the wheels. Never, ever would I change control arm width.
Old 01-29-2014, 02:22 PM
ok thanks, and how about the other question about measuring to see if a frame is square. Here's the deal, I have a 56 chevy truck and have a friend that has a truck with a camaro clip and he wants to go with a mustang ll so wants to sell the clipped frame but i want to make sure its straight and true, what points do i measure from and how do you measure ( like drop a plum bob down to the floor and measure between marks or use a string line or what? )
Old 01-29-2014, 04:04 PM
Wiki Edits: 326
Dropping a plumb bob from references that are the same location side to side in the front and the back of the vehicle is exactly how I have done it for years. If you have a relatively level floor, you can get real close using this method.
First thing to do is drop a line from each side of the differential housing to the floor and make your reference marks on the floor. Then do the same with left and right reference points at the front of the car. Then measure diagonally from the left rear to the right front and from the left front to the right rear. Both measurements should be the same. If not, something is out of whack.
Old 01-29-2014, 04:19 PM
ok that sounds good but how much out of perfect is acceptable 1/32 or 1/8 or what?
Old 01-30-2014, 11:35 AM
Wiki Edits: 326
1/16" to 1/8" is as close as I could ever get on a major project.
The Following User Says Thank You to techinspector1 For This Useful Post:
n2 cars (01-31-2014)
Old 02-09-2014, 08:14 AM
Fatman makes narrowed A frames for that clip that are 1.5" narrower per side.
Old 02-12-2014, 07:48 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Most of the older frames where built with a 1/4 in tolerance side to side. Which means a 1/8" difference. I've seen as high as 3/8 on a new car back in the day. If you can get it to 1/8" compareing side to side your good to go.
Old 02-12-2014, 08:21 AM
Exactly, there is your solution.
Yes geomotry changes a little but it's not that big of a deal in the real world.
Summit carries Heidts http://www.summitracing.com/search/p...t/model/camaro
This is why I don't like these swaps, they are done way too often. There are disc brake conversions that would have went right on that 55 front suspension and it would give you basically what you have in one afternoon but there would be no problem with the width. http://www.ebay.com/bhp/1955-chevy-brakes I'm not posting this for you, yours is done and you will make it work but for someone in the future searching frame clipping on the forum it may save them some headache to just get the disc brake kit.
Old 02-12-2014, 09:07 AM
thanks to all
Thanks to all who posted. In retrospect what sounded like a good idea has evolved into embarassment, my bad. thanks again
Camaro Subframe lt1tyrell Suspension - Brakes - Steering 12 11-30-2008 07:20 AM
Camaro Subframe lt1tyrell General Rodding Tech 1 11-09-2008 07:09 PM
Looking 4 Subframe For 81 Camaro UNDERWNG Body - Exterior 2 08-02-2007 11:01 PM
67 camaro subframe question dboyett38606 Suspension - Brakes - Steering 6 02-03-2007 10:29 PM
Camaro subframe bigbada1 Hotrodding Basics 8 11-16-2006 06:28 PM
