camaro timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 06:58 AM
camaro timing
1988 iroc 305 tpi .My book says to set timing at 6 degrees,internet says 12 and Friends say 0 degrees.Would like some advice.Thanks Tim
Old 06-05-2007, 10:37 AM
65 crusier man
Greeitngs,
If the engine is stock and the book is from chevy then go with the book. If the above doesn't apply then you may have to try the other settings to get the desired result.
I have a 65 land crusier with a 455 buick and I literaly have to place a cup of water on the radiator and time it till the water settles as smooth as i can get it. Then it runs beatiful.
Old 06-05-2007, 12:02 PM
misfire
thanks for a reply.My book is not from chevy,Chiltons 82 to 92 repair manual,and i have come across wiring that does not match,so i don't trust book.it will run at 0 to12 degrees,but i am getting misfiring in 3,5 cycilenders,and no codes,but if i disconnect the bypass wire the engine runs great which its not supose to .
Old 06-05-2007, 12:52 PM
malc's Avatar
Living At The Speed Of Life
I have the Chiltern book here in front of me, where does it say 6º ?
They give 5º BTDC as an example of how timing works and state you should time your car according to the emission control label in the engine compartment.
As various engine combinations are in use, the book only tells you how to do the job.
Old 06-05-2007, 01:40 PM
timing
you must think i'm a idiot or something! If you say you have this very book in front of you,YOU might want to turn to chapter 2-13,too many people seam to know whats going on but talk is cheap.
Old 06-05-2007, 03:48 PM
malc's Avatar
I did not imply or say you were an idiot, calm down.
Is this what you are using a chart from Chapter 2-3 ?
Does your car still have the emissions label under the hood, if so cross check with the Chiltern book.
(2-13 is an Ignition System Check, Chart C-4A, no timing degrees there.)
Old 06-06-2007, 12:48 AM
malc's Avatar
BTW, looking at the book chart for my Camaro year it states 6º whereas the sticker stated 0º.
Read the small print on the chart I posted, the underhood label takes preference.
Important you get the misfire cured, is the ignition all up to scratch and how do the plugs look ?
Can´t understand it running okay with the ECM disconnected, no spark advance.
I had to get a new ECM for mine, $100 reconditioned from a GM dealer.
Go try get one from a salvage yard.
(As mine was a carbed motor I was able to dump all that computer stuff.)
Old 06-07-2007, 06:49 AM
timing
I'm cooled off now,too many people telling me what to do and it's getting me poor results,not to mention the cash. Anyways,i had a chance to scan car and code 36 so friday i'll have a chance to hopefully get it fixed,one other thing,when we got in it said that it was the wrong ECM.We unplugged it and tried again and then it was fine.I'm got a buddy with a 86 ECM,he's going to lend it to me,hope takes care of that TIM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
68 firebird to camaro rear seat 68birdman Interior 24 11-23-2007 11:07 PM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
Timing Advance concerns Irnguy Engine 6 07-20-2004 10:16 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
