Camaro Tip - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 06:40 AM
Camaro Tip
Here is a tip for moving around camaros that have had the subframe removed. Take a rocker panel clamp, seperate the two halves and bolt them on where the subframe bolted to. Take a 2X6 and clamp it to the clamp halves. Then you can put you floor jack under the 2X6 and move it around. If you have to move it over an area where the jack can't go the shell of the viehicle is lighter than you may expect and you may be able to move it by hand.
This isn't just for camaros it works with most viecals built with a subframe.
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 11:01 AM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 06:54 AM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 09:29 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
