camaro tub - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2013, 12:41 AM
camaro tub
im am going to tub my camaro(when i get it) but i want too keep the back seat, i am thinking bout a 10 inch tub is that too much? can i go more? would it look bad if i went more? this is gonna be my daily driver
Old 08-29-2013, 04:15 AM
astroracer's Avatar
You need to know tire and wheel sizes, offsets and back spacing. What "look" are you going for? Pro-Street? Pro-Touring? Will you be narrowing the rearend? What rear suspension and frame are you thinking about? There is a TON of things you have to consider before you can do this correctly.
Doing a 3 or 4 inch tub, maintaining the stock diameter, should allow you to keep the back seat but, a 10" tub is huge and, when going this deep there is generally a larger diameter tire/drag slick being stuffed in there and that makes the back seat unusable.
Go here:
Chris Alston's Chassisworks
Poke around in the "install articles". Lots of good info here and it will give you a good idea of the tools, skill and time required to do this correctly.
Mark
The Following User Says Thank You to astroracer For This Useful Post:
MIYAGI708 (08-29-2013)
Old 08-29-2013, 08:31 AM
Go here:
Mark
I just want some meats under the rear end and thanks for the help means a lot
Old 08-29-2013, 09:03 AM
kso's Avatar
kso kso is offline
Mini-tubs were always a good idea for a street machine, and now there are very well done kits to buy or copy. I didn't get what year you have but for first- or second-gen cars there are these:
Google
Old 08-29-2013, 11:32 PM
vinniekq2's Avatar
what year Camaro? There is a lot of room in most Camaros
mini tub 1967 camaro 67-4-fun Suspension - Brakes - Steering 5 09-27-2011 08:35 AM
do I need to tub? torquemonster Hotrodding Basics 3 07-12-2011 08:19 AM
Tub a 69 Camaro Camaro2 Suspension - Brakes - Steering 5 11-25-2009 10:03 AM
Would I have to tub for these? 67_Deuce Suspension - Brakes - Steering 4 01-29-2003 06:21 AM
To tub or not to tub..... phreaekie Suspension - Brakes - Steering 9 12-18-2002 12:04 PM
