Jay,
I can only help with the cooling question. As far as the tranny the T5 won't live long behind the 383 if you beat on it but, on street tires you will more than likely smoke the tires before you break anything. If you are going to run a 180* stat (which is what I would suggest), you need to run the fan sending unit that is on @ 200 and off @190 (out of the two choices you listed). The reason is if you get the off @ 170*, you fan will never turn off due to your stat not allowing the temp to drop below 180*. Keep looking around they do make adjustable sensors (I know Vintage Air carries them), I just installed one on my car last night. It has a knob on it so you can adjust the temp at which the fan is activated. I can come up with a part number if you need it. Royce |
Check out www.thirdgen.org you will find alot of good info there on our cars
. That site has saved me on more than one occassion.
A reply on the T-5 tranny. First thing I did was update the shifter with the B&M shifter kit. I went through 2 trannies in 15k miles and gave up and put a turbo 350. If you shift the car normal the tranny will do fine, though what I noticed was shifting from 1st -2nd it sometimes won't go in until the RPM's got below 6 grand. Though it was sure fun having a manual tranny. I would keep an eye on ebay for a lakewood bell housing.
Mat |
flywheel problem
I run a Vortec 383 in my slammed 78 Monte, the flywheel is a 21 lb 305 unit that i had balanced with the reciprocating/rotating assembly.
Any good machine shop should be able to balance any flywheel that you present to them, using your old flywheel balance factor for reference. I had it done on a 454 once when i went from auto to standard with a lightweight flywheel. A word of advice, the 383 when built right pulls like a mule, a good 3000 lb. after-market clutch is mandatory. Otherwise you'ii find out like i did @ 3500 rpm and up with the 4 barrel wide open, the (stocker type) clutch makim big smoke. |
