Camaro wheel studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2005, 09:48 PM
lluciano77's Avatar
Short changed on common sense
Camaro wheel studs
I got some ARP .580" knurl studs. They are too big even though the package says "late model disc, early drum brakes".
I called Summit today and got a moron operator. He told me they don't make studs for 10 bolt 8.5 factory axles.
I ordered the .486" knurl studs from a different operator at Summit. Will these work???
Old 10-25-2005, 10:59 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
It may use metric studs if the standard don't work.
Old 10-25-2005, 11:02 PM
lluciano77's Avatar
It is a '73 Camaro. There isn't anything metric on it.
Old 10-26-2005, 08:50 PM
Some of those catalogs are wrong. I don't know about a '73 Camaro, but my '72 Nova has front discs, and the knurl on the front studs is bigger than the knurl on the back ones. The NAPA catalog had them listed wrong, and I ended up walking all over Monroe LA one day looking for a few big ones.
Old 10-27-2005, 02:34 AM
bracketeer's Avatar
489 Lemans
Sorry, lluciano77 threw me. I assumed it was a 1977 since you didn't specify otherwise.
Old 10-27-2005, 08:46 PM
lluciano77's Avatar
I got the .486" studs today. They look like they will work.
I still have the .580" studs. I think they will work in my front wheels. Is there any benefit to studding the front wheels?
Old 10-27-2005, 08:52 PM
bracketeer's Avatar
489 Lemans
You only have to stud the front wheels if you are using hollow aluminum wheels such as Centerline, Weld, Bogart, etc.
Old 10-27-2005, 09:35 PM
lluciano77's Avatar
I have Centerline Convo Pros
Old 10-27-2005, 10:38 PM
bracketeer's Avatar
489 Lemans
The reason for lengthening the wheel studs is to pass tech at the track. Wheel studs must be threaded into hex portion of lug nut a distance at least equal to the diameter of the stud. Most ARP studs are long enough that the stud will protrude all the way through.
Replacing steering wheel? hcker2000 Interior 5 02-07-2005 12:40 AM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 06:35 AM
turn signal canceling - after market wheel cboy Suspension - Brakes - Steering 0 04-07-2004 07:34 AM
New Guy Randy Ferguson Hotrodders' Lounge 11 03-09-2004 01:06 AM
Wheel stud replacement method jpd37 Transmission - Rearend 3 06-18-2003 11:07 AM
