Camaro won't move until very high RPMs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2011, 02:19 AM
Okay, so I have an 89 camaro with the little 2.8 v6 and the 700r4 in it and have been using it as my daily driver. Well, one day as I was pulling out of a gas station, it randomly stopped moving as if the trans no longer engaged and would barely move only if revved up past about 5000. I eventually towed it to a place to work on it and took the trans out thinking the 1st gear clutch pack was gone and put in a fairly new 700r4 from the same engine block model and everything from a friend's camaro back in it. I filled it with fluid, moved it through the gears, and warmed it up to get the fluid correct. When I sat it down, it did the same exact thing. This led me to believe that maybe the torque converter is just fried or something, but at this point I can't be too sure. Any help and thoughts of what it may be would be awesome!
Old 06-04-2011, 07:18 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Install a pressure gauge. But I think you're right about tc
Old 06-14-2011, 01:28 AM
Yeah, good idea also, but it turned out to be the torque converter. Changed it, set the tv cable, and she's on the road again. Thanks
Old 06-14-2011, 06:03 AM
ProStreetRob's Avatar
5.7L S10 LS SS
Ya man anytime I cooked a TC thats exactly what happen, Glad to hear she's back up and running
Rpms too high prettyboyced Transmission - Rearend 25 11-26-2010 06:28 PM
high freeway rpms?rear end swap? bonzipenguins Transmission - Rearend 4 04-10-2007 01:26 PM
TH400 shifting high rpms dieselherb Transmission - Rearend 1 08-20-2006 12:56 PM
BBC hemorrhaging oil at high rpms - what's the deal? LeadfootBob Engine 8 07-03-2006 06:40 PM
Car is smoking at high rpms... redcamaro4spd Engine 4 12-23-2003 06:15 PM
