camaro82 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2012, 06:44 PM
camaro82
Hi all i got engine and cant found what kind is it dont know if you can hlp ?
casting# 3970010
engine code # MM01800
Its all i have hope some one can hlp me i wanna know how much hp i got :/
i have remove oil pan and i know its 4bolt main
Old 08-02-2012, 08:41 AM
K it looks like you have a 350 however more info is needed because all you have here is the plant code and material run code the numbers you need for proper id should be located on the little boss in front of the driver side head right behind the waterpump that is if the block has not been decked or shaved if it has there is really noway to tell without taking a head off and measuring the bore. Depending on the year the info you have provided comes up to the following options 80-83 truck 305, 77-86 truck 350 and 73-76 truck 400 however all the listings show the heavy duty casting
Old 08-02-2012, 08:51 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
^x2. We need to know head specs, cam specs whether they are factory or not, intake, carb, exhaust etc...
