Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camber and Toe Settings
Old 12-09-2010, 08:23 AM
sparkydog's Avatar
sparkydog sparkydog is offline
Spa Mercenary
Last journal entry: Updates July 2012
Now that my project truck (see photo) is running reliably I am moving into some new areas of inspection/repair. Last night I did a quick DIY check of the camber and toe. I used the floor leveling/linoleum tiles/strings method.
If I did it right, then what I found was:
.7* NEGATIVE camber (top of wheel leaning IN), .3* toe IN.
And what I think the factory specs are is:
.25* POSITIVE camber, .1* toe IN.
Do I have the right values for factory specs (1996 C1500 XCab)?
Is there any reason to set it up different than factory?
Thanks!
Name:	1st Joy Ride.JPG
