Camber and Toe Settings
Now that my project truck (see photo) is running reliably I am moving into some new areas of inspection/repair. Last night I did a quick DIY check of the camber and toe. I used the floor leveling/linoleum tiles/strings method.
If I did it right, then what I found was: .7* NEGATIVE camber (top of wheel leaning IN), .3* toe IN. And what I think the factory specs are is: .25* POSITIVE camber, .1* toe IN. Do I have the right values for factory specs (1996 C1500 XCab)? Is there any reason to set it up different than factory? Thanks! |
martinsr, u got that right !!!
What I am trying to ask is: does anyone know if the factory GM truck specs do indeed call for positive camber? And, does it look like my truck is running negative on purpose or is it simply a sign of wear or improper adjustment? And, what numbers do the board members think is a BETTER set of numbers if the factory ones aren't optimum? |
The factory alignment specs for many (most) rwd vehicles will allow for positive camber. I would get away from the factory settings and adjust yours with .5 degree negative camber. That will reduce some of the understeer that running positive camber will induce, and will generally decrease front tire edge wear. Depending on tire width (the wider the tire, the less toe-in typically) I would dial in about 1/8" toe-in. As to caster, start with about 3 degrees positive and adjust from there for how the truck feels going down the road. If the truck doesn't track well on the freeway with these settings, add more positive caster and maybe just a bit more toe-in.
I suspect the reason you have different readings from stock is due to the truck now sitting at a different ride height than when the original body was installed. Could be worn control arm bushings also, or both. Andy |
I just want to say that this site is the best ! The guys on here helping each other out is fantastic. A lot more rods will make it to completion because of the help we all get.
Thanks to all who have helped me.
| Why positive camber on my M II suspension? | staleg | Suspension - Brakes - Steering | 2 | 04-18-2010 04:43 PM |
| Narrowed C4 IRS.....camber question | Stovebolter | Suspension - Brakes - Steering | 0 | 08-05-2008 06:21 AM |
| caster camber toe in -how to adjust? | Slickriffs | Suspension - Brakes - Steering | 12 | 10-25-2007 09:12 PM |
| camber, caster, & toe | NorthStar | Suspension - Brakes - Steering | 3 | 11-15-2006 08:34 AM |
| toe in or camber first | helton | Suspension - Brakes - Steering | 2 | 01-02-2002 07:47 PM |
