The guy is selling them for $200 and they have been worked to 2.02's. We are building the engine and then finding a car to put it in which will be for the local show n shines and weekend track days and smoking all my turbo import buddies with a real car lol. I will switch to aftermarket eventually but just need decent heads right now. I'm leaning more towards the fuelies now that I know there are custom accessory brackets out there.
Yes I would
You could get the power steering bracket that bolts to the front header bolt. Then get ya a low mount for your alternator mount that bolts to the lower bolt holes on the block and the problem is solved.
![]() Jester |
If you want double humps use casting #186 last 3 numbers they have acc bolt holes they came on 69-70 z several othersnova chevelle, 461 -462 and 292 do not have holes ,they are offered with 202/160 also 194/150 check.i have several sets i use for restoration projects .you can buy a NEW set of aluminum heads for about same price as it will take to Correctly build the humps,probably make more power ,lighter weight you will need longer head bolts with aftermarket alum. as for the Rebuilt heads for $200 RUN FOREST RUN.
In addition to that install screw in studs if not done already! Jesterr |
Vortech heads for the most part are not that great. There is one vortech casting that beats the 461 or 461X heads. And one aftermarket vortech casting that is better. all the others are pretty bad. If you dont have that one then use the 461's.
Ported for ported the 461's are better. Stock they are good for 350-400 hp just like the good vortechs. But in your case i have a set of 461X heads on the orginal 327 in my garage. I went and purchased procomps for 600 bucks. In your case i would suggest you sell the 461's to a fool on ebay and buy aftermarket aluminum heads. The 461 go for more bucks than some of the cheap aluminum heads so why not get a good set. If you are dead set on vortech get the good ones from the gm performance catalog. Not the ones on ebay for 50 bucks they will suck just as bad as any stock head. The best vortechs for the street are pretty good. they do make more power than the stock 461 but only a few ponies nothing your going to miss. if the 461's are bolt on ready then run them if not go with good heads not ok or pretty good or they worked on my boat. Good heads will make the best bang for the buck not free or cheap ones. 461 X heads came int he 300 hp 327 back in the day. They do work ignore the vortech trap. Also vortechs dont have the same bolt pattern for the manifold as older chevy heads do. This has been gone over several times on this forum. Here are the correct vortech casting numbers. 5.7 Vortec Casting #s Myth 062 & 906 Last edited by hcompton; 02-07-2013 at 11:06 AM. |
I forgot to mention the 292 castings most are angle plug ,and the 461x and 462xx heads were called service heads .sold across counter at chevy dealers to racers at the time they were the best you could get .461 come on 327 with 275 ,300 325.330.350 and 365 hp engines the 186 came on 302 z and lt1 350 , either woul;d be a good choice for street use or restoration.
The X in located on the underside of the head on the bottom of the intake runner. cant be sean while the head is on the car. |
The X does not denote a larger intake runner. That is a popular wives tale. The X only means there was a change (in the mold) from original casting design. This could be most anything. From xtra thickness in a mounting boss/spring pocket to coolant passage mods.
Here are the FACTS: The ONLY significant difference in c/n 906 and 062 L31 production Vortec heads is the 906 head MIGHT have a hardened exhaust seat insert as opposed to an induction hardened seat. The insert MAY cause there to be a slight lip where the insert and head meet. And there might be a single angle seat instead of the three angle seat used on the induction hardened seats (this has to be verified). These differences certainly do NOT make the 906 w/insert a "bad" or "poor flowing" head. In fact, there are boat builders who prefer the insert seat heads. If the Vortec head as used on production vehicles has a problem, it's cracking- NOT flow. Some cracking isn't because of the heads per se; they cracked because of other shortcomings of the engine. IMO anyone who cannot get better performance from a Vortec head than a fuelie head- all else being equal- needs to work on their engine building skills. • Vortec heads Last edited by cobalt327; 02-07-2013 at 12:21 PM. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
malc (02-07-2013) | ||
I suppose I should also say the exhaust to intake flow ratio is not good. That's why unported Vortecs use a split pattern cam. Basic Vortec 101 stuff.
Sorry LOL wrong thread
Jester |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| 350 heads on 327 | 67camarokid | Engine | 4 | 11-23-2005 09:29 PM |
| Do Camel Hump Heads have a water sending unit port? | CHEV66JB | Engine | 6 | 05-12-2003 09:53 AM |
| bolt holes in 300 camle hump heads | 70 nova | Engine | 1 | 04-11-2003 06:56 PM |
| 350 heads or 305 H.O. heads????? | crshrmn3 | Engine | 3 | 08-25-2002 08:51 PM |
