Camel Hump Heads on a 350 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2008, 06:03 PM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Would Camel Hump Heads 62 cc 2.02 beat vortecs ?
These heads came off a 327 there cn is 3782461
If these r good how much hp per head and wat would be the compression ratio
Im trying to find out if these would be good heads for a 350 buildup
Old 01-09-2008, 06:27 PM
I am anxious to know also, I learned I also have the Camel Back heads with 64cc and 2.02 valves
Darele
Old 01-09-2008, 06:47 PM
the 461 heads are very nice heads, but the vortec is a little better performance wise. comp. varies depending upon head gasket used and how far down in the hole your pistons are, and if flat top or domed or dished. sam-missle
Old 01-09-2008, 09:03 PM
DoubleVision's Avatar
the camels dont have much hump compared to a vortec head. The runner of the vortec is far more efficient as is the combustion chamber.
Old 01-09-2008, 09:31 PM
MI2600's Avatar
Member# 3287
What DV said.
Old 01-09-2008, 09:41 PM
Ozz1967's Avatar
Air Force Guy
When chevy built the Vortec heads for their trucks, they inadvertantly created what at the time was the best production head ever made. Pound for pound, or in this case CC for CC, the Vortec beats 90% of everything out there produced before 1996. If you want to go for "old school" then go with the "double hump" heads. It's what I've got on my 67 Camaro. It's period correct but if I switched to Vortecs, which involves also switching the intake manifold, that alone would be worth 20-25hp.
Old 02-04-2013, 07:33 PM
I'm building my first engine and am trying to figure out which heads to use there is a guy in my local area selling a set of camel humps with 2.02/1.60 valves complete port & polished and have screw in studs. Would these be good heads to get me close to my goal of 400hp or should I look around for a set of vortecs? Would stock vortecs still be better than these?
Old 02-05-2013, 04:43 AM
Be aware the double humps don't have threaded holes for accessories.
Vortecs are better flowing, however they tend to crack.
Vortec also require a vortec intake, vortec rockers, vortec valve covers.
Vortecs require modifications to use more than 0.430" lift.
Vortecs flow poorly on the exhaust side. Headers and/or extra exhaust duration helps out.
Correctly ported double humps with screws in studs and 2.02/1.94 valves should flow better than stock vortecs. What diameter springs?
A 350 with flat tops and 64cc double humps should make around 10:1 cr. This compression is high enough to use a good size cam. But that would also require more gear and stall. What are you trying to do with your 350?
Old 02-05-2013, 06:55 AM
BOBCRMAN@aol.com's Avatar
Camel back heads are almost 50 years old. Have soft seats. Take large sp plugs. Are always "just rebuilt". Usually need $400.00+ work done after purchase. Have no acc holes. I see it all the time.
Old 02-05-2013, 07:20 AM
Wiki Edits: 27
cracks ?
Also small block heads have the two exhaust valves close together, that creates hot spots, I have seen quite a few cracked. besure to have them magnafluxed if you decide to use them.
Old 02-05-2013, 11:28 AM
A good set of 2.02/1.60, pocket-ported, port-matched camel humps with a GOOD 3-angle valve job is hard to beat and can exceed 400 crank hp in a normally aspirated engine.
The Vortec heads may have more potential, but there's a bunch of other stuff necessary to make them work.
Accessory bolt holes are "no thing" and there are nice mount on the market made to work with ALL TRUE Chevy SB heads.
Old 02-05-2013, 11:43 AM
The answer would be no, the L31 Vortecs will produce about 30 to 40 more horsepower and torque pounds out of the box. Lot of people give credence to the better porting of the Vortec which it has, the shape is different and the intake is raise about .1 inch which does a lot to improve flow into the bowl you can't duplicate this in any camel hump without getting wet. But the big advantage is in the chamber shape which while subtly different compared to camels is extremely significant in power production. This just can't be duplicated in older heads. The improved port position and shape combined with the elements of the combustion chamber shapes completely obsolete older heads regardless of valve diameter. Plus, the camels do not have hardened valve seats which are not compatible with today’s un-leaded fuels, the seat and valves will pound in pretty fast especially if the engine is used hard. As well as the camels don’t have the holes to mount modern accessories; depending upon accessory mount selection they can limit the engine to the short water pump which has a greater amount of difference in coolant delivery to the block’s left to right sides than does the better balanced flow of the tall pump. The short pump always runs the driver’s side of the engine hotter than the passenger side.
However, the L31 head does require a lot of modification when running an aggressive cam. It is lift limited by the valve guides which need to be trimmed for valve lifts beyond .45 inch. This is no big deal but is an added expense. The OEM valve springs were made to operate with the truck cam so they are not strong enough for a performance cam let alone a competition cam. The raised intake port requires caution when enlarging the spring pocket so the pocket doesn't break into the port nor weaken that area to where although not penetrating the port will result in a fatigue failure that cracks into the port at a later date. So large diameter springs are risking the casting. The answer here is to use Beehive springs, the big reason for old fashion high pressure springs was to control the harmonic response of the spring itself that resulted in valve float. The modern approach is to use a variable spaced wire wind that combines with reducing the wind diameter at the top as well as often using an ovate shaped wire rather than round wire. If you will, it’s modern rocket science versus old time brute force to get to the needed performance. Hardly anybody in professional racing uses two and three individual springs anymore and haven’t for many years. The L31 Vortec is also designed for self aligning rockers so it does not have cast in push rod guides. When using standard un-guided rockers it becomes necessary to modify the rocker stud bosses to accept screw in studs and guide plates, something usually done for a performance modification anyway. The older heads also use a larger sparkplug which is a real pain with headers. These heads also raised the rocker cover rail so oil leaks out of the heads are a thing of the past. The L31's do not have an exhaust crossover, therefore, has no means of heating the intake manifold if that is desired and if used on the street where EGR is required, this must be externally plumbed from the exhaust manifold/header tube. All of this adds enough cost to the basic L31 to make looking at other ready to race GMPP Vortec or Fastburn heads, or shopping the aftermarket if the engine is going to be much different from OEM production use. There are many great aftermarket heads out there that are comparable. One needs to be careful with used aftermarket heads as the L31 Vortec totally changed combustion chamber design which was quickly incorporated into the aftermarket in the last part of the 1990's. So earlier designs though less expensive are also less powerful. Look at pictures of the L31 Vortec combustion chamber very carefully, you want to duplicate this or come very close in any aftermarket head. The major features you're looking for are the dual quench (something the camels also have) but the L31’s include a relief between the intake and the sparkplug which is actually there to remix the separated fuel and air streams as they enter the combustion chamber, the spark is plug moved as inboard to the center of the cylinder as possible and positioned by or at least aimed at the exhaust valve, a shallow combustion chamber depth with the plug being close to the roof, and beak that projects between the intake and exhaust valves.
Now under the head you want tight clearance between the piston and head where the squish/quench chamber is formed. For a street engine; this needs to be .040 to .060 inch the lesser amount being the better for combustion. Compression is very cam timing dependant, these new heads like a fairly short cam with a fast lift rate using high lifts compared to the old muscle car cams that have a lot of total duration with not a lot of lift where much of the duration is used in long ramps. In the end the Dynamic Compression Ratio (DCR) which is driven by the closing point of the intake valve will drive the Static (measured by volumes) Compression Ratio (SCR). The Vortec chamber will tolerate more compression ratio against fuel octane than will the old camel hump which is a big advantage when today's pump fuels are pretty much limited to less than 95 octanes. This advantage will easily allow the L31 Vortec type head in cast iron run at 9.5 static against a mild cam where the camel hump will not tolerate that combination. If you go to an aluminum head you can push that static another point higher and will want to do so as the added thermal efficiency of high compression is needed to overcome the faster heat transfer rate of aluminum over cast iron in order to gain the power potential in aluminum heads. The piston choice will need to dial in the compression ratio while maintaining proper squish/quench. Depending on chamber volume and whether the block is zero decked or not the piston crown will vary from a flat top to a D or even stepped dish. The OEM piston and simple OEM style replacements use a circular dish. This has the effect of increasing the clearance between piston and the squish/quench deck of the head which reduces this function. This makes the engine much more detonation and preignition prone. Think of squish/quench as mechanical octane, its effects are of pushing the mixture to the sparkplug side of the chamber which speeds the burn rate at the start of ignition this is squish; then as the flame front progresses across the chamber becoming hotter and increasing pressure as it goes, the same close association of piston to head now sinks out the excess heat which delays the point where the mixture will explode ahead of the flame front causing detonation this is the quench function. These things can make the fuel behave as if it has 5 or more higher octanes than its pump rating.
All of these design features come together to support the high power outputs and efficiencies of modern engines. The L98, L31, LT1 and LT4 were all huge improvements on the basic Gen I and related LT versions of the Gen II SBC but they could only point the way to the need for an entirely new GEN III the LS series to really allow complete integration of these new ideas that were add-ons to the GEN I and II engines. If you've been up against a stock GEN III motor you already know that these engines will have the hottest of the camel hump engines for breakfast. It is in the Rocket Science so the more of this you can cram into an old GEN I the better it gets so the L31 head and its many clones are a huge step in that direction.
Bogie
Old 02-05-2013, 12:12 PM
This thread is 5 years old, instead of restarting it you could have just started a new thread.
Old 02-05-2013, 08:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Personally of the two (fuelie or Vortec) I would go w/Vortec heads, preferably either aftermarket or already reworked for more lift like is sold by Scoggin-Dicky and others.
The fuelie heads were good in their day, but that day has passed. Some do have accessory holes, but more don't than do. None came w/hardened exhaust seats. Not a deal killer, but something to be aware of.
The Vortec heads will make 400 hp easily. The fuelie heads can also make 400 hp- but it'll take more cam to get there. Overall, the Vortec heads are a much better design. The downside is supposedly finding good castings is hard, although I have had no problem in this regard. Just make sure to have them inspected before buying, or only pay core price for them if no inspection/guarantee.
The aftermarket has come to the rescue on the problem w/not enough clearance for a high lift cam (over about 0.420"- 0.460", depending on the casting). Comp has beehive springs and retainers that allows plenty of lift w/o machining anything (below, right).
More info here.
Old 02-05-2013, 09:00 PM
The market for aftermarket heads (iron and aluminum) existed because ported factory chevy heads were so notorious for cracking. If the water temp got above 220 you pulled into the pits and prayed. I think the doublehumps are best reseved for restorations and period pieces, I'm really suprised that someone hasn't cast a doublehump with a modern combustion chamber and heavy walls.
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
350 heads on 327 67camarokid Engine 4 11-23-2005 09:29 PM
Do Camel Hump Heads have a water sending unit port? CHEV66JB Engine 6 05-12-2003 09:53 AM
bolt holes in 300 camle hump heads 70 nova Engine 1 04-11-2003 06:56 PM
350 heads or 305 H.O. heads????? crshrmn3 Engine 3 08-25-2002 08:51 PM
