Cameo Panel Restoration & Repair
I have acquired a Cameo bed which will require some rehabilitation. One panel has two severe cracks on the front quarter and both will have to be completely stripped.
As I am new to fiberglass repair I am looking for suggestions as to the best approach to this challenge. My thought are to sand the panels to remove the paint layers using 80 grit on a palm sander. I am thinking a DA would creat ripples in the material. Would a chemical stripper be better? Once I have the paint removed is there something I should do to seal the old fiberglass such as re-gelcoat it or will epoxy primer be sufficient? The repair method for the tears I was thinking of doing included sanding the tears to create a bevel and a clean contact point along the tear. Then use fiberglass matt strips laid in lengthwise down the tear. How many layers should I try to achieve? Is there a recommended repair kit or materials I should source? Once the fiberglass cures I expect to knock it down with 80 grit and then apply some filler. I typically use the dynalite brand filler. Is there a better one to use on fiberglass? |
cameo and corvette cracks
I had a 57 cameo and my brother had a 57 corvette. Both had severe cracking. My brother said that was a common problem in those days . I traded it off, never fixed it. when we fixed his dune buggy body we also added a lot of matt and epoxy resin to the inside,
reposted same
too fast on the keys
Dont use chem strip on glass...sand or blast it...
| garage wiring | montea | Garage - Tools | 33 | 01-18-2007 08:33 AM |
| wanted: an answer to a simple question | ikeaguirre14 | Body - Exterior | 4 | 05-15-2005 07:23 PM |
