camero A-arm bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2005, 06:40 PM
I am building a 57 short box ford F100. It has a camero front stub of unknown year. I need to buy new A-arm bushings to reinstall the front end with the stiffer springs I have purchased. How can I get bushings to match the upper and lower A arms if I do not know the year of the camero donor car.
Old 12-14-2005, 07:57 PM
MechaNate's Avatar
Planet moving torque monster
70 through 81 should all be the same and is the most prevalent of years used to "camaro clip" vehicles like yours was.
Old 12-14-2005, 08:58 PM
There are actually two different bushing sets that cover those years. There is one for the early ones up to about 74, and the other fits the later ones. As I recall, the lower arms on the early ones had two different diameters on the front and rear bushings, while the later ones, had both bushings the same diameter.
Old 12-15-2005, 06:43 PM
MechaNate's Avatar
Thanks for the correction- I ve run into this before and guess I got lucky picking the year- Dint know there was a year/ design break between 70-81 glad somebody knew that- it may be helpfull to me at a later point!
34 coupe control arm bushings jaxhome Suspension - Brakes - Steering 9 06-03-2005 01:56 PM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
Control Arm Bushings 69 chevelle SS Suspension - Brakes - Steering 1 08-10-2003 07:50 PM
78 nova control arm bushings brad_irc Suspension - Brakes - Steering 1 07-20-2003 08:08 PM
Help!!! Control arm bushings! arborlis Suspension - Brakes - Steering 5 03-22-2003 05:57 PM
