cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2008, 05:37 PM
cams
I have a pickup s-15 with a small block 355 comp cam 480-480 flat top piston alum heads 750dp carb alum intake also. I have a 350 tans with a 3500 stall converter and a 410rear gears. i like to know if i would be better with a roller cam or stick to the hyd or solid lift cam. like to get this in the 12s if i could any help would be great. thanks
Old 09-27-2008, 09:26 PM
Your aluminum heads are... ???
Cylinder heads are all important in the go fast deals. What heads do you have and what intake manifold? Tell us what you have, specifically, for your combo, everything.
Comp Cams Xtream Energy 268 camshaft chevymastermind Engine 15 05-22-2007 05:15 PM
Cams Cams Cams chevymastermind Engine 6 02-26-2006 05:05 AM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
Truth about, emmisions and cam's stereodud Engine 16 11-18-2002 03:25 PM
