cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2010, 06:14 PM
cams
hello,
im pretty sure this is a dumb question but when im looking at cams for my engine and it says basic rpm range of like 2500 - 6000 or something like that, does this mean that my car will sit there and idle at 2500rpms?
Old 06-09-2010, 06:23 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
No such thing as a dumb question, And no it don't mean it will have to idle at 2500 rpm. Those # s are the power range of the cam is from 2500 to 6000 rpm.JMO
Cole
Old 06-09-2010, 07:01 PM
i`m guessing that it all depends on how far the RPM drops when u shift gears? like a close ratio trans drips only 500 rpm, like that of a muncie. OR like a c4 that drops alost 1000 at 800
Old 06-09-2010, 09:36 PM
techinspector1's Avatar
Wiki Edits: 326
Any camshaft you bolt into the motor will have an effective operating range of about 3500 rpm's. It will not be effective and make good power from idle to redline, but only in the range outlined. Let's say you wanted the cam to make power right off idle, then you might choose a cam that makes power from 1000 to 4500. At 4500, the motor would be running out of breath and you'd have to change gears to drop the rpm's down under 4500 for the motor to pull again in the taller gear.
Now, on the flip side, let's say that you are like most other young persons who thinks more cam makes more horsepower, regardless of static compression ratio or any other consideration. Most everything on and in the motor is stock, but you decide that a cam that makes power from 4000 to 7500 will be the hot ticket. You bolt it into the motor and now can't understand why the motor will not pull the hat off your head under 4000. Let's say you installed this cam and then installed a 4000 stall converter so that the motor would rev up past the range where it makes little or no power. This might be going in the right direction, but you still have stock heads on the motor, so it will run out of breath at 5000 or 5500 and you still have built a turd. You now only have a power range of 4000 to 5500, a 1500 rpm window of operation.
Once you understand that all the parts of a motor must be coordinated together to make power through a pre-determined range, then you will be a good amateur engine builder.
Old 06-10-2010, 12:00 AM
you know techinspecter1,
i think i have learned more from you in your responses on my posts then just about anything.
thanks a lot
Old 06-10-2010, 02:56 AM
Wiki Edits: 326
You're welcome. Many people have taught me, I'm just giving some of it back to fellows like you.
Old 06-10-2010, 08:55 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
the advertised operating range for sbc cams is also rated for the 350 not all sbc, and the rule is the more cubic inches it has the cam it will eat up. so say the operating range of the cam is 2500-5500 for a 350, that same cam in a 383 will have an operating range more like 2200-5200, and for a 400 it will have and operating range of 2000-5000, but in a 327 it will have and operating range of 2800-5800. do you understand this. so it when picking a cam you also have to pick one that will be right for you specfic motor and the intended driving it will be used for.
confused about camshafts (FSB) pstrbrc Engine 9 11-30-2008 08:02 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
Know of any good cams? TurboS10 Engine 19 12-20-2004 01:46 PM
Truth about, emmisions and cam's stereodud Engine 16 11-18-2002 03:25 PM
