cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 04:38 PM
cams
puttin cam bearing in 1970 trans am 455 need to know if there is a certin bearing for each bearing hole .are yhey all the same?
Old 11-04-2012, 05:21 PM
BOBCRMAN@aol.com's Avatar
The bearings each have a number on the back side. If the numbers are all he same they can be installed in any bore. If not. The box they came in usually has position of each bearing printed on the inside end flap.
I havent done a Pontiac in a while. But, I'll tell you it is not an engine to learn on. The cam bearings in the factory install are bored after install..
The replacement bearings usually require "fitting" of the cam. A bearing knife and Scotchbrite. This can be time consuming.
Old 11-04-2012, 05:29 PM
all the numbers on the bearings are the same, there are not any numbers on the box tabs. im not sure thats the reason i was asking
Old 11-05-2012, 07:28 AM
Pontiacs use the same bearing in all 5 positions. Not an uncommon question, as most V8s don't (Lima or "385" Ford is another).
Jim
Old 11-06-2012, 08:22 AM
Never had a cam hit a rod in a Pontiac. What ARE you talking about? NOT a Chevy, you know. The space between the cam and crank is greater than that of a BBC. The standard deck Pontiac (10.240") is .020" TALLER than the "tall deck" BBC (10.220").
Jim
Old 11-06-2012, 12:22 PM
Our "package" 461 has a 4.25" stroke and valve lift of .620". Have NEVER seen what you're talking about with anything but a Chevy. This does assume, of course, the rods are installed "forward" and not "backward" (like most non-Pontiac builders do to start with), but even that doesn't cause rod-to-cam interference.
Jim
comp cams XE cams my87Z Engine 52 08-15-2012 01:09 PM
Do roller cams sound meaner than hydraulic cams? 4speed57 Engine 22 10-28-2009 01:08 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 03:01 PM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
good cams, bad cams jackflash Engine 14 08-29-2003 11:13 AM
