camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2010, 10:00 AM
crowerjunky's Avatar
JOHNNY
camshaft
i have a solid roller 243/248 668 lift i would like for it to have more duration something around 250-/250 can it be cut down that much to get that much an how much lift will be lost
Old 11-18-2010, 10:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Instead of trying to regrind an existing cam, it will be easier, quicker and cheaper to find and buy another camshaft w/the specs you want.
Old 11-18-2010, 10:55 AM
ericnova72's Avatar
More for Less Racer
By reducing the base circle when they grind it, it is possible to grind a new profile that would have more lift. Whether it can be done on your core will depend on several things : current base circle diameter, what the current cam core part # is for heat treat depth to be determined9can't grind it too thin ), what the current lobe sepreration is(also ties into hardness depth, cores have a small range of seperations that can be ground on each core blank), and maybe a couple other criteria that I'm not thinking of right now.
You will pretty much have to discuss this with a cam regrinder, and possibly send it in for them to inspect to find out what is possible on your core.
Camshaft identification Ratoflic Engine 4 08-31-2010 09:25 AM
camshaft question crussell85 Engine 21 07-24-2010 10:42 PM
Rotella Motor Oil boss350 Engine 14 04-18-2007 12:00 AM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 09:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 05:04 PM
