camshaft 283 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2012, 03:20 AM
we have a 283 small block chev v8 . we would like to know please some information fitted to this engine. as the engine was a rebuilt unit and the prior owner is now deceased i have nothing to go by. therefore i have removed the camshaft and would like to know any information you may be able to give. the numbers on the camshaft are as follows : gm6 73279 thankyou
Old 12-17-2012, 03:54 PM
techinspector1's Avatar
Wiki Edits: 326
Not that it'll mean much, some 50-odd years after it was built at the factory, but maybe there is still a stamped alpha/numeric code on the passenger side block deck, right at the front of the block that would give you a little history on the motor. There is also a large casting number on the bellhousing flange. If the motor is still in the vehicle, it can be read by shining a strong flashlight on the number and using a telescoping mechanic's mirror to read it. Neither of these numbers will I.D. the cam, but may provide information that can be chased down later on to add to the known history of the motor.
Your screen name could mean that this motor came from your '56 Chevy and in that case, if it's the original motor for the car, it would be a 265, not a 283.
283 small block chevy goldenbullet44 Engine 11 06-16-2010 06:05 PM
Small Block Chevy Camshaft Goldduster360 Engine 4 11-27-2007 08:27 AM
please help!!! new 283 chevy small block 11toe Engine 6 05-19-2006 05:54 PM
283 small block chevy? Balz Engine 3 06-11-2004 11:22 AM
283 small block turbo's demon1957 Engine 6 12-20-2002 05:58 AM
