camshaft for 67 327 sb - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2012, 05:16 AM
alsanchez1161's Avatar
i have a 67 327sb on a 68 chevy c10.i have 3.08 open diff its came with 882 heads and a 2bbl rochester carb,i just bought a street/strip 600cfm carb with dual pane intake manifold from summitracing wich i plan on putting on once i find the perfect cam could u guys give me a hand with this issue
Old 01-17-2012, 10:40 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
882 heads are 76cc combustion chambers, so when bolted onto a 327 with stock-type pistons and piston deck height, even with a steel shim gasket, the static compression ratio will be in the range of 8.00:1 (I did the math and found 7.99:1). Using any kind of performance camshaft with 8.00:1 static compression ratio and a 3.08:1 rear gear is gonna be a big disappointment to you in my opinion. What the motor needs is a bone-stock cam with 0.050" duration under 200.
Old 01-17-2012, 11:39 AM
lg1969's Avatar
Google "Tunnel Ram 406"
You be lucky if it's going to produce power. With low compression and 3.08 gears is like a 400lb person riding on a tricycle. No go!
Old 01-17-2012, 12:17 PM
well whaT do u guys recomend i do with this 327 i dont want a 350 cause every one has those few have 327 so i want to b a bit different this is my first engine build but deployments have made it difficult to start but now ima have plenty of time any recomendations on getting different pistons, i realy dont know wer to start i need ideas
Old 01-17-2012, 12:31 PM
lg1969's Avatar
Sell the 327 build a 383 or a 406. You will be ahead of the game.
BTW: Get gears like 390 or 410.
Old 01-17-2012, 12:43 PM
but i also want a kind of daily driver and not break the bank thats y id figure throw like 1g into the engine and it should get me atleast close to 300hp
Old 01-17-2012, 12:45 PM
Senior Curmudgeon
Wiki Edits: 326
No matter what you do to the motor/trans, you will need gears, so you may as well pull the diff out of the truck and start there. Everyone should begin at the rear of the vehicle. Gears first.
Old 01-17-2012, 12:58 PM
lg1969's Avatar
Focus on the gears and get overdrive tranny. Install the carb and intake on the 327. Long tube small dia. tube headers will help the low end.
Old 01-17-2012, 01:10 PM
well forgot to mention i already have long headers true dual all the way to the back,,and what kind of gears do u guys recomend
Old 01-17-2012, 01:34 PM
Vortec heads, a 262Hyd cam and the requisite Vortec manifold.
If you want to go with a stick, the T5 conversion I mentioned before is fine, it'll be over 2grand unless you build the trans yourself from cores. You'll need V8 Camaro or Firebird guts, with an S10 T5 tailhousing and speedo arrangement. I'd still like to see you in the 3.42:1 axle range to be able to use the OD
Or, you could find yourself an M20 or a 2.64 1st gear T10 or a similar Saginaw 4spd and jack the axle to a 3.55 or 3.42
Or a 2.88:1 T10 or similar Saginaw and your current axle. Avoid the 3.xx 1st gear T10s and Saginaws...not strong enough and parts are hard to get.
If your motor is running now, don't mess with it. Fix the brakes, get a better axle (3.42/3.31 or 3.23s) and put any of those transmissions in it I mentioned...THEN build a solid motor and make it an awesome driver that rides nice, stops good and has a bench seat and 3 pedals
Old 01-17-2012, 01:59 PM
very good advice i greatly appreciate it i guess ill leave that CAMSHAFT ON THER for now and take care of my diif before anything else i had just boughten the 3.08 cause thats what a local mechanic recomended well didnt know much at the time about diff but should of know 3.08 way out of my leuge for what i want
need camshaft jjoeworks Hotrodding Basics 2 05-22-2009 08:21 AM
camshaft / ID 74novaman Engine 0 03-22-2009 10:02 PM
Camshaft Help! jgreene6611 Engine 1 12-03-2007 07:16 PM
camshaft I.D. camaroboy1991 Engine 4 12-02-2007 10:13 PM
camshaft racer 78 Engine 6 03-11-2006 12:50 PM
