Camshaft advice. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2012, 07:22 PM
Camshaft advice.
Hello guys.
I'm throwing together an engine for my lil Chevy Monza
TH-350 trans with 2500 stall converter. (may have 3500 that i might use if that's better)
4.10:1 gears and 28" tires
Engine vise i have is a std 4 bolt 350 with dish pistons. (9.25:1 comp)
64cc 215cc aluminum heads. (yes i know on the bigger side, but i got them, so why not use them)
Performer RPM intake manifold and 750 Holley DP carb.
Exhaust consist of 1.5/8" long tube headers and dual 2.5" exhaust.
I don't mind running solid cam if i have to.
Can you guys suggest a cam for my street strip Monza, As i don't want to choose way to big of a cam, and don't wan't the car to be total dog on the street !
Best regards.
Old 05-23-2012, 08:13 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What's the volume of the piston dish? I see 9.4 c.r. with flat tops, .025 in the hole, for your setup.
Semper Fi
Old 05-24-2012, 03:28 PM
I may have messed up my calculations, but the pistons are stock dished, iirc they are -16cc dish and i will use 0.015" head gasket,
Best regards
Old 05-24-2012, 05:04 PM
Sbc 350, finishing touch, camshaft
Can someone on this fantastic forum give me some good guidelines on choosing camshaft for my car, or recommend someone that i could talk to that can.
Old 05-24-2012, 05:38 PM
What would be the best way to do that, and what would be ideal compression ratio? I want it to run on regular pump gas.
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 04:21 PM
Camshaft Advice for 396 BBC ? monzter Engine 7 03-02-2010 11:39 AM
camshaft advice for BBC Johnny4311 Engine 3 06-29-2007 02:00 PM
Camshaft Help Lumpy Engine 6 12-27-2004 12:07 PM
