I'm in the process of building a 468 right now and i'm gonna be going with a hyd. flat tappet cam. Either Extreme Energy or Extreme 4x4. Both give you good torque from the git go. Leaning toward the Extreme 4x4 part# 11.239-3. It's good from 1600-5800 rpm. Hopefully that helps alittle!!
you are correct with wanting a smaller cam (judging by the gears, stall, and tires).
However, the compression ratio would be to high to drop a cam size. First, double check your compression values. If the cr is correct (10.5:1) then consider dropping the cr down to 9.0 to 9.5 and use a cam in the 218 to 224 degree range with 112 lsa. |
You might want to think twice about using a flat tappet cam in a BBC. A friend of mine who builds them for a living will not install a flat tappet cam into one without the owner signing a release form that states when the cam goes south, it is not the shop's fault. He says the BBC is the worst motor out there for eating flat tappet cams.
Think about it. No amount of money saved by using a flat tappet over a roller is worth the hassle of completely disassembling the motor to clean out the shrapnel from every nook and cranny, then having to buy a roller cam ANYWAY, along with all the gaskets, seals and time required to reassemble the motor. Buy a roller cam and be done with it. |
You can find it on page 221 here....
http://www.compcams.com/products/212-225.pdf 11-691-9 will not show up in the Spec Card Search. |
| camshaft question | crussell85 | Engine | 22 | 07-24-2010 09:42 PM |
| Rotella Motor Oil | boss350 | Engine | 14 | 04-17-2007 11:00 PM |
| Just did a TBI conversion and need some advice | ghomer | Engine | 8 | 12-28-2006 07:16 PM |
| 1998 Chevy Venture camshaft | kberly54 | Engine | 2 | 07-14-2005 08:09 PM |
| How to choose correct camshaft | Drag1racer | Engine | 0 | 07-08-2005 04:04 PM |
