Which Camshaft is better for the Street on a chevy 383? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2013, 08:43 PM
XR258HR .480/.487 lift, LSA 110 1000-5000RPM
XR264HR .487/.495 lift, LSA 110 1200-5200RPM
XR270HR .495/.502 lift, LSA 110 1600- 5400RPM
I was wondering would the smaller camshaft give me better street manners at a lower RPM but i never planned on using the RPM past 5500... Or do you think that all these camshafts would perform very similar with each other?
Also its for 1978 chevy truck big ten, has 22 in wheels with low profile tires (265/35/22), will have a 700r4, has 3.42 gears (might upgrade to a 3.73 in the near future) and i will use the edelbrock rpm cylinder heads 64cc with a 185 intake runner and a 9.5 compression ratio... my driving nature is cruising from time to time then when im on the highway i either cruise or drive like a getaway driver and possibly a little stop light racing but nothing too big... this engine will be a street engine only no strip or track... this so far is my biggest set back...
also check out this website that uses two of the three camshafts listed above... 383 Chevy Engine - The Ultimate 'Stick
Old 02-05-2013, 09:23 PM
vinniekq2's Avatar
I would use the xr 270 in a truck. You as a driver have to determine best what suits you. I would use that same cam in a 283 in a small car,,,,
The Following User Says Thank You to vinniekq2 For This Useful Post:
demarques_191 (02-05-2013)
Old 02-05-2013, 09:24 PM
with low compression and high gears with no stall use the smaller cam.
the taller wheels and tires will change the ratio as well, the engine isn't going to build big hp with what's inside of it, so do yourself a favor and use the smaller cam.
The Following User Says Thank You to prumora1 For This Useful Post:
Old 02-05-2013, 09:34 PM
vinniekq2's Avatar
prumora,could you show me the math on your idea please?
Old 02-05-2013, 09:56 PM
vinniekq2's Avatar
all 3 cams have a lda of 110 and 4 advance on the intake side
XR258HR this cam would make peak power at 4000 rpm or less
XR270HR would at least make power to 5k or a bit more in a "383" this would get the engine over 400 hp and make great torque from 1800 rpm up,the 258 cam would likely be under 400 hp ,may as well build a 350
demarques_191 (02-06-2013)
Old 02-06-2013, 01:10 AM
Well there isn't that much difference in any of the cams. If I were buying the cam for my 383 ci I would purchase the XR264HR .487/.495 lift, LSA 110 1200-5200RPM. Recommended gear ratio 3.23-3.73. Stock converter.
Old 02-06-2013, 11:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If your static compression ratio is 9.5, the dynamic CR would be below 7:1 w/the 270 cam. That cam mean a significant and unnecessary loss of power from what the cam could make w/more compression.
Old 02-06-2013, 11:56 AM
vinniekq2's Avatar
270 cam
what are you using for intake closing ?
Old 02-06-2013, 12:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nevermind, it's closer to 7.8, that is if comp uses an IC on the seat on their cam card.
Old 02-06-2013, 02:59 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Ya know.383's do like you to lean on the exhaust side a little bit.Just a thought to throw on the pile.
Old 02-06-2013, 05:14 PM
there seem to be alot of different opinions and its a street motor, your saying the XR270HR isnt a good cam for the 383 with 9.5 compression? There was a site that compares all of the xtreme camshafts with 9.25 compression
http://www.strokerengine.com/CompCams.html take a look and you tell me what you guys think
Old 02-06-2013, 05:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your CR is OK w/the XR270.
Old 02-06-2013, 05:43 PM
vinniekq2's Avatar
compare apples to apples
look at the heads they are using.ouch,for power,,,,
Old 02-06-2013, 06:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't know what's a 'stroker' about a 0.030" over sbc 400 (406 in other words), either.
Old 02-07-2013, 06:12 AM
@vinnie right lol and imagine putting some good flowing heads how much power you can ahieve then lol
building the right street setup for a 383 chevy demarques_191 Engine 29 02-04-2013 11:56 PM
Hydraulic Flat or Roller??? Chevy 383 Street engine? 89SDime Engine 38 02-23-2011 12:00 AM
Help Choosing Roller Camshaft For 454 Street Car leejoy Engine 1 11-28-2007 09:07 PM
383 Camshaft Mightymouse Engine 10 08-08-2004 12:20 AM
