camshaft degreeing sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 12:40 AM
Hello, I am trying to get some simple guidelines on camshaft degreeing,
I have looked at several web sites and have found differnt information,
and I have not ever done this so I want to be sure of what I am doing.
Thanks
Old 03-28-2006, 09:06 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Comp cam web site has what you need. A link at the bottom nearest the right side.
Old 03-28-2006, 09:37 AM
Last journal entry: PICTURE TEST
cam
What part of the process don't you understand... Maybe we can help...
what part do you understand...
Keith
Old 03-28-2006, 11:19 PM
Keith
Hey Keith, well I was just confused about what I was reading about turning the engine over ( to piston stop ) then back, and the multiplying and division.
I went to a friend of mine today who is a engine builder and he made the prossess alot simpler for me by having me use a dial indicator to find TDC.
That was what I was confused about.
Thanks for your reply, and I will more than likely have plenty of more questions in the future. I am building a 383 and had to get one of those small shaft cams for rod bolt clearance, ( comp cam ) It has been ran before but I am freshing it up and I have never degreed a cam before. I found out it was at seven degrees BTDC and the cam card says fifteen, but my engine builder friend did some math and told me to set it at nineteen BTDC, I am sure he knows because he builds alot of high dollar race engines I just hate to bother him too much because I know alot of people are always asking his advise. Thanks again..... Al
Old 03-29-2006, 05:17 AM
cam
Ok,,,Sounds like your on the right track.... One quick way to double check your self is to check the valve events to what the card has listed....
Keith
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
camshaft degreeing decomposer Engine 6 06-12-2005 06:18 PM
Help me design a 400 SBC around this camshaft shockers69 Engine 9 02-12-2005 08:27 AM
Identifying sbc camshaft jdreher Engine 0 03-16-2004 01:06 PM
another sbc 350 camshaft question....... Thacolbster Engine 2 01-30-2003 11:30 AM
