camshaft gurus help?
ok now i have an intresting way of looking at this, my applicant idea is very simple. 400 sbc with 500 ft pounds at a 1000 rpm, (stump puller) but very flat torque like to 6000 rev limit with a peak hp to 5800 rpm. Many might say it wont do good with the 1/4 mile, but i say it will do decent with a 1/4 mile (if tractions at its best) now it is quite difficult to think of which is right for this appliction... Not to many would do it. Ok rear gear will be 2.73:1 ratio (idea is the steep or a lil lower would be great to twist with 500 ft pounds) or a lil lower. TH350 or TH400, 1500 stall or even factory. The cam shaft im looking for specifically needs to be a power band of 1000-5000ish or more rpms would be great. Any options or suggestions on how to get this application tight like that? Thanks and sorry about this if its annoying question, pretty sure you guys have better things to answer. Im really wanting to make it right on par
