Camshaft help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2010, 08:59 PM
Hillhippy
Camshaft help
96 L31 in a 96 GMC Safari. Van to be used as daily driver and to pull a 22 ft camper. The motor was bought mid rebuild. New .030 pistons. rod and main bearings. New cam bearings installed.new valve guides and seals. 3 angle valve job. New valve springs. No camshaft. lifters. Any help on a cam would be greatly appreciated. So basically I bought an expensive anchor for my boat. Should have stuck to Ford. Thank you anyway
Old 05-16-2010, 09:21 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
The one that's in it now.
Old 05-17-2010, 01:59 AM
Hillhippy
L31 motor bought minus camshaft
L31 motor was bought mid rebuild. No cam or lifters came with it. Bore is .030 over all parts are new and the heads have been redone. Need advice on a cam
Old 05-17-2010, 02:12 AM
DoubleVision's Avatar
Then we need more info. Your running Vortec heads I`m guessing since you say it`s a L31, were the guides clearanced so you can run a larger cam? This a daily driver? What`s the rear gear ratio? What transmission, auto or stick? What intake? what carb?
How far down is the pistons at TDC? what thickness head gaskets? are the pistons flat tops or dish tops? The cam is the brain of the engine, we got to know all the info on the engine before we can tell you what cam.
Old 05-17-2010, 02:39 AM
Hillhippy
More info
heads are vortec 090 casting number and have not been clearanced pistons are flat top head gaskets ard felpro ordered for a the motor through napa.Automatic transmission that came in the 96 4.3L Safari and stock gears stock intake and efi unless it needs changed to get the results Im looking for. This is my first chevy build.
camshaft question crussell85 Engine 22 07-24-2010 09:42 PM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 08:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
Identification of my Erson mechanical camshaft regens sum Engine 2 06-03-2004 03:23 PM
