I would suggest the 262 or even the 268xe grinds by comp. That's only because I've heard about them, and I am not familiar with the others.
Now, about this your vehicle will roll and might choke and die... I don't know where that was going.
Look, if you add too much duration it will, of course, decrease your bottom end torque and add more hp. If you add just the right amount both will go up.
The reason you would want to run a higher stall converter is because you're not going to have low-end grunt. Like, if you ride in an LS1 car, it takes off moderate, but once it gets going well-then, it's all hades breaks loose. It's the same thing. Your new powerful cam will take off markedly slow, but when it's in it's "sweet spot" it will then pull better.
A torque converter works like two fans. If you have a oscillating fan and you position it to blow on another fan that isn't on, the other fan will be caused to move by the fan that is on. That's how a torque converter works. Your engine is fan #1. It spins, and once your engine revs reach a certain speed fan#2 (transmission input shaft) starts to spin.
In a stock converter, they will hydrostatically (they have transmission FLUID in them, hydro=fluid) lock together at a low speed. This means you might get close to 1:1 at 1600 rpm. Now being your stock engine made good grunt at this low engine speed, that isn't a problem. With the new cam you can potentially loose some low-end torque. This will cause you to make less power at the lower rpm speeds. So, what worked fine at 1600 rpm before doesn't cut it now. Your engine is missing and isn't running smooth and powerful. If you try to take off with not enough stall you engine and transmission will be connected and your engine is going to have to really struggle to spin, and it will have to struggle even more to gain rpm's. Once it does overcome this and get up to a certain engine speed it will accelerate fine.
So, if you get a converter with a higher 'stall' speed, you will move that 'hydrostatic lockup' point higher into the rpm range. This means that now at say (if it's a 2500 rpm stall) 2500rpm you get your 1:1 with engine speed and transmission input shaft. This won't snap into action will will be gradual somewhat, but should "flash" close to the full stall rating. Now, say put your vehicle in low and punch the gas your engine speed jumps up to 2150 rpm and that's where you start your engine accelerating from.
You don't have the lowend torque you used to have, but you make more power higher in the rpm range. The converter will just allow you start off higher in the rpm range where you are making more power.
I finally understand this stuff somewhat. If you have questions, post them. I'll answer if they're not answered. Don't be afraid if you need a stall. If you can do a cam you can easily change a converter. You can pick up a B&M converter (2400 stall) for $150. You can get their 2800-3200 stall for two hundred and something.
You might be able to get away with no stall for some cams. Once you get it installed, if it is sluggish off the line add more stall speed.
For the guy that said you car would choke and die. With the stock converter you can take your foot off the brake and the car will roll. With a higher stall converter this will not occur as strongly.
One last point to mention. If you run a high gear like you are saying, you won't turn a lot of RPM cruising. If you get a 3 grand converter you will need to cruise close to 3000 rpm, or it will slip. If it slips you will waste fuel. Your economy can suffer. Converters that slip also make a lot of heat. Heat is what kills your transmission. Make sure you put an aftermarket cooler for your tranny.
So, if you're not willing to run more of a gear, don't get a big cam. You'll need a bigger converter and you won't cruise at enough rpm to do so economically.
You really should make a cylinder head choice before you buy a cam. People who have seriously fast cars do that. They pick their heads, and then send them off to be ported and flowed. When they get the flow numbers they have a custom ground cam that will keep up with the heads.
Make your head choice first. That way, you only have to do the cam once.
If you have large intake runners on your heads, that's the same as having a big cam. For instance the torquey Vortec heads have a 170 cc intake runners. Small block race heads could have 240cc intake runners. Go for a conservatively sized runner, and pick a cam that will make power in the same area.
Sorry if this is too long. It's almost over.
220/226 @ .050 462"/470" 112 LS
That's the cam you want.
Right now I have a 212/222 with .435"/.460" on a 112LCA. My cam is in a 350 with 9.1:1 compression. I have a 2400 rpm converter with 3.43 gears and a th400 tranny. I feel like I need more converter. If I had more, I'd leave the line harder. That's a fairly aggressive cam you have picked out. You'll hear a noticeable lope with that one.
Also, you'll need around 9.5-ish:1 compression if you want to run a cam like that. You can do it with less, but that will hurt your bottom end torque. You'll want to get at least 9:1 compression or more. I don't know what your compression would be with the stock bottom-end, but if it's in the eights that should be addressed as a concern.
What heads are you considering?
Hope this might have answered something.
Post any more q's.
Ben T.
