camshaft identification mfg. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 03:42 PM
I have new,dont know how new ,never installed cam part #965332 G for a 351C ford 1972 4V engine no other info available as to Mfr. specs whatever. can anybody help? wendellpage@q.com Thanks.
Old 01-02-2013, 04:12 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Use a micrometer or calipers to measure the major diameter and minor diameter of the lobes. Subtract the smaller number from the larger number and that is roughly the lobe lift. Multiply that by the rocker arm ratio and you have the advertised lift for the cam. To find duration, intake centerline, exhaust centerline, lobe separation angle, overlap, etc., you will need to set the cam up in the block with the #1 piston, rod and crankshaft, along with a timing chain and sprockets to find piston TDC and then work your way into the other numbers from there.
Powerhouse Products Universal Cam Checker - Camshaft Tools - Valve Train Tools
https://www.youtube.com/watch?v=-iKV3CkfEXQ
Camshaft identification, need help Ratoflic Hotrodding Basics 12 09-22-2011 11:38 AM
camshaft identification Ratoflic Engine 2 02-12-2010 12:46 AM
Camshaft Identification jbvcw71 Engine 2 09-07-2008 09:47 PM
camshaft identification help yodert75 Engine 2 11-19-2006 01:31 AM
Camshaft identification help frog454 Engine 2 02-11-2003 05:31 PM
