Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camshaft Indentification
Old 01-06-2013, 04:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Hotrod1979 View Post
I checked the number on the back site of the Cam.
The engine is not taken apart..
Might want to see if there's any ID markings under the cam gear.
I agree 300 is the advertised duration.
You can see if it's a solid or hydraulic and if it's a flat tappet or roller (be sure to not mix flat tappet lifters up- the lifter is married to the lobe it was used on). I suspect it's going to be a flat tappet hydraulic, like 99% of the SBC cams being used today.
Measure the valve lift at the pushrod and see if that, along w/the 300 degrees advertised duration, matches up to anything.
