camshaft installation?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-06-2004, 09:00 PM
Originally posted by fireforsin
okay but how do i put the distributor in to get it closest to the timing specs?
To it it close to the timing spec once you've every thing lined up at TDC, oil pump shaft engaged and rotor pointing to # one. Rotate the engine to the timing spec, such as 10* ATDC. Now with an HEI distributor rotate the housing until the triangluar shaped pole pieces in the bottom of the distributor are alined point to point and lock it down. With a point distributor turn the housing until the points just break open. should be timed close enough to start it. You can check by cranking the over with the starter with a timing light hooked up before you get gas to the carb. With a helper it shouldn't need to be cranked more than 2 or 3 seconds to verify the timing.
