camshaft for lifted truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2012, 11:40 AM
I am doing a frame off resto on a 84 chevy shortbox 4" lift 33" tires3.rw gears th350 trans performer intake 750 holley stock heads gasket matched just a weekend truck no mud or trails too much time and $$ invested for that looking for a cam with a little thump at idle but nothing to crazy
Old 05-23-2012, 01:30 PM
Banned
need a lot more gear.
Old 05-23-2012, 06:53 PM
Needs a smaller carb, too. 650 is right for a stock-headed 350 and a flat tappet hydraulic cam. You'll get more out of a good "competition" type 650 than a street DP 750.
The cam is the "upper end" of the intake's capability. If you want more revs and less low-end, use Performer RPM and the 750. It's a bit of a miss-match with small valves and low comression. I like the Perfomer/650 combo better. More head work would wake it up with the "bigger" parts.
FWIW
Jim
Old 05-23-2012, 06:56 PM
Thanks guys
Paint lifted with tape removal. Metallic BC/CC 67Elcamino Body - Exterior 6 05-22-2012 11:20 AM
check out my 4x4 suburban video and also 4x4 lifted van bcacali24 Hotrodders' Lounge 2 04-10-2008 01:46 PM
02 F250 HD Diesel Lifted customized tranny issue? Big_Diesel Transmission - Rearend 9 08-18-2007 05:43 PM
looking for *************lifted off ******** pittviper_012 Introduce Yourself 1 06-23-2007 01:32 PM
Dropped/Lifted Spindles For Diesels? TheGreatWhay Suspension - Brakes - Steering 4 11-19-2003 12:44 AM
