Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camshaft LSA?
Thread: Camshaft LSA?
Old 03-15-2004, 09:31 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Your lower number LSA cams will tend to be peakier in the power band, but will make more power in the "sweat spot". The higher number LSA cams will have a flatter power band with the better idle as mentioned. FWIW most all of your large race cams use a tighter LSA(smaller number, usually 106). If forced induction or nitrous are in the plan you want to keep away from the 106 range cams.
Chris
